My brother rolled his powerstroke
Old Feb 6, 2011 | 04:08 PM
F350Fummins's Avatar
Default My brother rolled his powerstroke
Ok so this morning he was headed to get some mc donalds for breakfast and one tire went in the ditch and somehow it flipped the truck on the roof. Cab is completly junk, but question is it sat upside down for a half hour and oil came out of air filter, so is the engine junk or what?
Old Feb 6, 2011 | 04:22 PM
gamaliel's Avatar
if the engine was not running while it was upside down then i will say its ok.
but if the engine was running while the truck was upside down, then most likely is junk
Old Feb 8, 2011 | 04:36 PM
bobfbigman's Avatar
6.0s will not run without oil////trust me// it is a good design, the high pressure oil pump is what gives the injectors pressure, once that sump is low the engine will shut down..
The way I know this I had my bypass filter/that some else tightened/ loosened up and spun off. I dumped 4 gallons of oil in about 100 yards on the road just as I was taking off from a traffic light by my house, luckily it was late at night, had to call 911 so they could put some oil dry down, amazing when you see how little the orfice is in the bypass restrictor.
Oh yeah, I bet that was the most expensive breakfast he has ever had, that sucks, hopefully he is allrite.
Old Feb 9, 2011 | 12:35 AM
EasternAggie's Avatar
Same goes for the 7.3 bud. Like you said, the oil is what fires the injectors, so when the oil gets too low it wont even throw in fuel.
Old Feb 9, 2011 | 12:39 AM
Captain Call's Avatar
Shouldn't be junk, we've had equipment at work upside down till we could right it and it wasn't junk.
Old Feb 10, 2011 | 01:19 PM
white93's Avatar
It should be alright. Just pull the glow plugs and suck the oil out of the cylinders so it doesnt hydrolock when you try to start it.
Old Feb 10, 2011 | 03:16 PM
gamaliel's Avatar
ill take it back
sorry for my bad input
chrispowerstroke09
Oct 10, 2015 12:04 PM
Lsugod85
Jun 20, 2015 05:14 PM
Justin82
Price Quote - Request A Price
Apr 1, 2015 02:22 PM
makuloco2000
Feb 15, 2015 02:31 PM
