engine to trans adaptor plate thickness
Old Jan 14, 2011 | 10:45 AM
Walkenvol's Avatar
Default engine to trans adaptor plate thickness
How critical is the thickness of the adaptor plate when mating a straight shift tranny? Does it cause trouble if the transmission shaft tip doesn't fully seat into the crank bushing by 1/16th of an inch? I would think it would be bad for the fit to be too tight, but as long as a significant portion of the transmission input shaft fits into the crank bushing it seems like it wouldn't cause a problem. What do you think?
Old Jan 14, 2011 | 12:09 PM
FTE's Avatar
FTE
Not only do you hve to consider the pilot but also the release brg. depth. It should be as close to the same specs. as the app. the trans came from.
Old Jan 14, 2011 | 12:12 PM
Walkenvol's Avatar
Sort of tough to get exact. Some amount has to be OK doesn't it? 1/16, 1/32, 1/64, 1/128?
Old Jan 14, 2011 | 01:47 PM
rab475's Avatar
most of the time the tranny doesnt seat against the bushing. I measured from the bellhousing to the bushing on a stock application then on my mercedes and got within 1/8 inch it worked fine. I think anything witin 1/4 would be fine after that its too far. This is just my opinion.
Old Jan 14, 2011 | 09:20 PM
jeep-dsl's Avatar
i seated mine till it was touching then pressed it toward flywheel 1/16th more. Its been fine.
Old Jan 16, 2011 | 11:00 AM
beerbellykelly's Avatar
just the info i was looking for too-i,m still jigging my set up around-sweet.
burndiesel
10
Feb 7, 2023 01:15 AM
cmine615
14
Apr 3, 2017 09:12 PM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Dec 23, 2014 11:40 PM
wisakowsky
Oct 14, 2014 08:13 PM
