white smoke no power
Old Jan 13, 2011 | 04:17 PM
rab475's Avatar
Default white smoke no power
Im looking at a 01 f350 that starts up fine in the cold but blows white smoke at idle. If you try to rev it up it cuts out bad and pours white smoke it smells like a mist of diesel. Truck has 150k on it and was owned by the railroad. Has a lot of blowby when cold but is started great at 25 this morning. He pulled the air intake and the turbo spins fine but if you block the blowby vent it builds pressure fast.
Old Jan 13, 2011 | 04:37 PM
CSIPSD's Avatar
Sounds like a cracked injector cup, broken nozzle or a cracked piston... Take the oil fill cap off, flip it over and set it on top of the filler neck. It will vibrate off, but it should not blow off.
If it blows off, more or less needs a motor.
Old Feb 6, 2011 | 10:52 AM
dieselbomb87's Avatar
mine was doing this the other day it was cold. but its cause my engine was cold. and had the heater on. once it heated up all was good? idk if this will help.
Old Feb 7, 2011 | 02:26 PM
articfox's Avatar
sounds like injectors or something that has to deal with fuel. white smoke ussaly means two things one your motor is burnning oil i doubt it on yours, but i think your not geting enuf fuel but it seems serious get it looked at
Old Feb 7, 2011 | 03:50 PM
95powersmoker's Avatar
Not exactly. Burning oil usually is seen by blue smoke.
Old Feb 7, 2011 | 07:36 PM
7.3 Cowboy's Avatar
Mine has a haze of white smoke all the time at idle or if its around 0 outside it has it even when im driving
Old Feb 20, 2011 | 11:22 PM
frankiebright's Avatar
Default whitesmokes when first cranked but stops when he motor warms up why does it smoke
my 97 F250 white smokes when first cranked up but stops when it warms up what could it be but the glow plugs is good
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
Timglow546
8
Jun 3, 2015 10:13 PM
shawnecarter
May 11, 2015 02:47 AM
