2004 F-350 6.0L Troubles
Old Dec 19, 2010 | 11:30 AM
quest99999's Avatar
Default 2004 F-350 6.0L Troubles
Started no prob. Will idle in gear and rev fine in park and neutral. Put in drive or reverse and try to accelerate and truck shuts off then does not restart. After a while it will restart again. Every once in a while will run fine down the road then same issue. Has had alot of the 6.0L issues over the years and and been to the shop several times. Any suggestions what this one is?
Old Dec 23, 2010 | 09:47 PM
farmingsthelife's Avatar
i dont know, but check the transmission wire harness. we had something similar to that happen on a 7.3 e-550
Old Dec 31, 2010 | 09:22 AM
it deff sounds like a wiring issue
Old Jan 8, 2011 | 10:39 PM
Red_Rattler's Avatar
High Tech Redneck
Figure this out?
JaysTruck
Jul 22, 2015 11:49 AM
HKLBRY
Feb 18, 2015 09:46 PM
HKLBRY
Feb 17, 2015 08:52 PM
Alwaysgone
Jan 21, 2015 04:55 PM
Dec 10, 2014 08:10 AM
