sponge brakes 1997 f 250
Old Dec 14, 2010 | 11:13 PM
kingd91's Avatar
Default sponge brakes 1997 f 250
anyone no the name for the vacum pump running off the belt in front of the motor and what they cost,i think my brakes are lacking vacum.new master and pads and rotors
Old Dec 21, 2010 | 07:15 PM
cody73's Avatar
I am pretty sure its just called a vacuum pump, but before you buy one try bleeding the whole brake system again because master cylinders can be a little tricky some times as far as getting all the air out, and a spongy pedal means air in the system, and no vacuum causes a stiff pedal like when you apply the brake before starting. Just pull a vacuum test on it, but my bet is you still have air in the system somewhere
Old Dec 26, 2010 | 11:36 PM
farmingsthelife's Avatar
yes, the vacuum going out isnt going to make the pedal more easy to push. Since the brakes are vaccum assisted, loosing vacuum will just make the pedal extremely hard to push.
Radioking1777
Jun 9, 2015 04:13 AM
thatdude38
May 9, 2015 12:21 PM
kryz9903
May 4, 2015 05:00 AM
12valvedually96
Mar 17, 2015 06:00 PM
Feb 18, 2015 02:40 PM
