48re issues
Old Dec 13, 2010 | 05:20 PM
Redneck GI JOE's Avatar
Default 48re issues
so i was throwing codes P1751(Trans Throttle Valve Position Minimum Range Performance) and P1753 (Trans Throttle Valve Performance). I was told by someone one here to change out the Throttle Valve Actuator. Done. All was fine for a day, then it went back to taking off really slow with high rev hitting bout 4K RPMs, then shifts. occasionally i will be sitting still and it will jolt forwards, the jolt will lurch the truck forward almost feeling like ive been hit from behind. i just turned 101,000. its mostly stock. with replacement of the Throttle Valve Actuator i flushed trans, new filter, no more then the normal crap in the pan. some other people on here have suggested to change out the governor pressure sensor/transducer (also seen listed as trans speed sensor) and the governor pressure solenoid. could this have anything to do with the CPS? ive been getting codes for it to. please help guys
Old Dec 14, 2010 | 09:47 AM
DangerMan's Avatar
Default THE MAN TO CALL.
Garmon's Diesel Performance
404-557-4972
Ask for Jeff Garmon...... The Man. Period.
If He's not around, Try Google searching Leadfoot diesel. Their real cool and easy to deal with. Its a family business.
Good Luck
dwmeehan
Jan 29, 2025 12:13 PM
Ric Stokes
Aug 31, 2015 06:58 AM
culp7
14
Jul 20, 2015 10:13 PM
ronstop
Feb 26, 2015 09:48 AM
Polaris04
Dec 1, 2014 08:27 AM
