EBPV as an exhaust brake???
Old Dec 11, 2010 | 08:05 PM
DieselDanBoy's Avatar
Default EBPV as an exhaust brake???
I have a 97 f350 psd, i've been hearing alot about wiring in a switch to manually open and close the ebpv to use as an exhaust brake. anyone know more about this??
Dan
Old Dec 11, 2010 | 10:43 PM
white93's Avatar
I had one on my old psd and it worked and sounded pretty good. I just spliced into the wires going to the pedestal and mounted a switch on the shifter. It only took me 30 minutes to do.
Here's a copy of the instructions that I used to make mine.
Turning your Exhaust Back Pressure Valve into an Exhaust brake!!!
Locate the 2 wires that plug into the EBPV and unplug them from the pedestal
Cut the gray w/ red wire a couple inches back from the plug
Connect a wire from the gray w/ red wire from the plug and run into the cab
once inside the cab put in a lighted toggle switch and connect 12v (Switched power) to it
this is so when you turn on the toggle switch it will send 12v (Switched Power) to the EBPV and close it
I like having it this way so that you have complete control over the EBPV so you can close it to warm up the truck or for an exhaust brake
I also recommend you doing the TC lockup mod to because you would want them both on for the engine braking to work in your lower gears (Automatic only)
***This modification is not intended to be used under 30mph or 1500 rpm.***
***If you have an automatic transmission you will need to do the torque Converter Lock up Modification!! (Manual transmission are good to go)***
***Use caution it only takes 72psi of back pressure to lift a Powerstroke factory exhaust valve off of its seat and into the upcoming piston in other words do not push the skinny pedal when operating the exhaust brake***
Old Dec 12, 2010 | 12:27 PM
CSIPSD's Avatar
Works great! Ran it for years on my 95, 97, 99 and my 01 when I had the valve.
Make sure you do not hook up the PCM side of that wire to 12v or you will cook the PCM.
Old Dec 13, 2010 | 01:08 AM
ok and this is the stock ebpv on the factory garrett turbo right?
White93 thanks for the instructions. but hooking 12v to the wire that comes from the pcm wont do damage?
and the 75psi of backpressure, is it something i need to worry about considering i have a home made intake and dp tuner? (3" mbrp downpipe coming soon) the tuner has a high idle tune (1100rpm) for the purpose to help warm up faster. it gets cold here in northern ohio haha
Old Dec 15, 2010 | 08:50 PM
cowboyjohnson's Avatar
try this Tips - Idea - Hints
its about a third of the way down the page. worked for me
Last edited by cowboyjohnson; Dec 15, 2010 at 08:50 PM. Reason: Automerged Doublepost
Old Dec 15, 2010 | 10:39 PM
white93's Avatar
I wouldn't worry about the back pressure,it should be ok as long as you don't mash the pedal to the floor with it on. I'm not sure on the pcm wire. I hooked 12v directly to the solenoid and ran it manually with a switch.
Old Dec 17, 2010 | 10:56 PM
fordornothing's Avatar
i attempted to do this on my 94 PSD but mine would just click but it wouldn't close. what would i have to do to fix this?
Old Dec 19, 2010 | 02:31 PM
ok, so having a high idle tune shouldnt do anything? just make sure to turn it off before i take off and i should be ok?
and for the pcm wire, im just gonna cut the pcm wire off and cap that off real good and just run power to it, no chance of cooking the pcm then
sounds like a bad ebp valve or if you hear a click maybe the vacuum solenoid??
anybody have a better idea on that?
Last edited by DieselDanBoy; Dec 19, 2010 at 02:31 PM. Reason: Automerged Doublepost
Old Dec 19, 2010 | 02:34 PM
99stackedpowerstroke's Avatar
so i would be able to do this on my 99 psd? and do these all come with the valve?
Old Dec 19, 2010 | 02:39 PM
yes you can, im here at college in ohio and my roommate has a 2000, i was just talking with him and discovered he did it so im gonna have him show me. he cut both wires to the ebpv and made his own power and ground through a switch.
