Dodge Diesel Tech Articles All Years of Cummins Tech Talk
OIL Fill Cap / Breather Vent Mod
Old Nov 12, 2007 | 10:49 AM
IC Smoke's Avatar
Default OIL Fill Cap / Breather Vent Mod
If you are running high boost and crank case pressure this is a good mod for you!
parts list
Dremel
Gorilla glue
Oil cap- Napa P/N: 703-1458
Breather Filter- Auto Zone P/N: 3998 Brand "Spectre"
clamp the cap in a vise with a rag or small towel (not too much or you'll break it) then drill a hole about 3/4" or what looks to be large enough for the rubber tube from the breather will fit in BUT not to big where it will be loose. I used a Dremel side Drill and then a deburring tool to finish up the hole. then put some glue on the rubber part of the filter as well as the oil cap. push in and youre done!
Note- test fit all your parts prior to glue! AND my filter was a little loose from the rubber gromet that was supplied so I glued that as well to keep it from vibrating while the motor is running
a couple pics:
LAmiller's truck from CompD.com:
Ian
Old Nov 12, 2007 | 10:53 AM
Johnny Cetane's Avatar
Very nice job.
Old Nov 15, 2007 | 10:59 AM
Joe Diesel's Avatar
nice mod
Old Nov 15, 2007 | 11:58 AM
IC Smoke's Avatar
Thanks guys
Ill let ya know how it goes once I get the rig back!!
Old Nov 15, 2007 | 05:17 PM
cashwheel's Avatar
Damn, one more idea to steal from you. If you keep putting this stuff on the site our trucks are going to be identical.
Old Nov 15, 2007 | 08:30 PM
IC Smoke's Avatar
hahah Thanks! anything you want to do next? I like to work on projects and improve them.
Old Nov 16, 2007 | 10:47 AM
DBogo's Avatar
whats the best way to do this on a 12v
Old Nov 16, 2007 | 04:57 PM
IC Smoke's Avatar
Big Bad Dodge did it!
here is the link for the 12V scroll all the way down to almost the bottom and you'll see:
http://www.bigbaddodge.com/Motor.html
Old Nov 17, 2007 | 02:21 AM
Parttimepuller's Avatar
Default good
LOOKS good !!!!!
soco
Jul 27, 2015 06:06 PM
cutthroatxxx
May 18, 2015 11:10 AM
JPT18
Mar 11, 2015 04:25 AM
Oltian.
Diesel Bombers Sponsors
Feb 24, 2015 10:07 PM
12Valvepower01
30
Nov 11, 2014 10:52 AM
