01 Transfer Case Model???
Old Nov 28, 2010 | 11:53 AM
dmaxtothemax's Avatar
Default 01 Transfer Case Model???
I've got a 01 2500HD LB7 4wd... How/where do i find the model and/or assembly number(s) on the transfer case? Thanks
Old Nov 29, 2010 | 11:38 AM
Rttoys's Avatar
There is a round tag on the back of the t-case, near the drive shaft area. It will say New Process...bla bla bla
Old Nov 29, 2010 | 02:11 PM
BriteWhiteRam's Avatar
why do you need the T-case #?
Old Nov 29, 2010 | 10:05 PM
well, i guess my lack of knowledge would be there reason... I don't need the transfer case digits... sorry for the mix up... (btw, i did find the info on the t. case)
From my minimal research, i guess i meant the differential or front gear box (4wd - front drive mechanism)
Anywho, the reason being is i wanted to find a diagram of the thing to better understand how it all works and how the actuator engages/disengages... I wanted to get some general knowledge of it... Im a mad D.I.Y.er just cause i love it...
Old Dec 2, 2010 | 11:03 AM
1AMatt's Avatar
Site Sponsor - 1aauto
I believe because there are two different types of transfer cases. One with Auto 4wd and one without auto 4wd.
Also Brianwhiteram is correct. Simple little round tag on the backside of the t case. Usually metal with red writing on it.
Old Dec 2, 2010 | 02:10 PM
Rttoys's Avatar
Old Dec 2, 2010 | 03:13 PM
the front Axel is an AAM 9.25
American Axle & Manufacturing (AAM) - Front Axles theres not a lot of info here, but I couldnt find much.. im sure if you poke around on the internet long enough you could find more info
Its Brite whiteram btw...
Old Dec 3, 2010 | 01:17 PM
very good my Britewhiteram friend... Thanks a bunch... I will do some research and maybe get to be more educated about all this... thanks again everybody
russellflemister
Apr 12, 2015 05:34 PM
Jrod89
Feb 24, 2015 09:48 PM
crawlright
Nov 29, 2014 01:45 PM
N1ght train
Nov 7, 2014 07:50 PM
steves2500diesel
Oct 14, 2014 05:36 PM
