Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Opinions
Old Oct 16, 2010 | 09:24 PM
MechanicalDiesel's Avatar
Default Opinions
I just bought a pair of Kenwood 6x9's (KFC-6982IE) apparently there supposed to be 5 way speakers and got pretty good reviews but I wanna know if anyone on here has an personal experiences with them? Plus ive been hearing that I might need to make up some spacers cause some 6x9's are to deep is this true? thanks guys
Old Oct 16, 2010 | 09:45 PM
RAW's Avatar
RAW
I've never heard of 5 way speakers, looks like they will hit every Hz! The 6x9's in the doors are pretty big, at least with the infinity system. I put some after-market infinitys in with no problem.
The mounting depth of my Infinitys is the same as your Kenwoods, you should be set. Both are 3 1/16" mounting depth. You may have an issue with the protrusion of the 4 way block, it will make contact with the door interior, more than likely.
Old Oct 16, 2010 | 09:46 PM
Yeah they seem like they would be powerful enough only $70 off amazon and its peak watts is 500
Old Oct 17, 2010 | 12:52 PM
Deezel Stink3r's Avatar
Don't go by peak numbers, they are only what they are:"peaks"!
Nobody knows how long that peak is: a nano second( a billionth of a second?) 0.000000001s.The manufacture usually uses these numbers to pimp the numbers a bit.
For that reason the only value which can tell you anything about power handling abilities is the true rms value.
Do not assume a lot of "ways" result automatically in better sound. You would be amazed how easy a good 2-way speaker system can outperform a x-way system.
Have you had a chance to "compare " your speakers in advance with other speakers??
Old Oct 18, 2010 | 06:45 AM
I personally never got to compare but there rms is around 120 I think. I wanted to hear them but no one I knows has them, I just based my opinion of them off of others reviews which all seem to be good. They seem to be a pretty good bang for there buck
Old Oct 18, 2010 | 02:44 PM
Just take your time for a good install. No air leaks,a nice and tight mounting and you will have a really good bang for your buck. Have fun with the install.Are you going to use an additional amp for those speakers?
Old Oct 18, 2010 | 02:57 PM
At some point yes but I wanna buy a really nice headunit first, any suggestions?
Old Oct 18, 2010 | 03:47 PM
What about Alpine? I love the Imprint system and the full Ipod connectivity.
I still use an old Blaupunkt with an harman drive+play ipod control- works fine.
Old Oct 19, 2010 | 01:49 PM
AdrianD's Avatar
What connectivity do you need ? USB ? SD Card ? Ipod ? Bluetooth ?
How many RCA outputs ? I assume at least one would be mandatory
Jmrobinson
Sep 11, 2015 12:30 AM
wannadrag
May 25, 2015 03:07 PM
kobe123
Apr 30, 2015 12:00 AM
Krizacosta915
12
Apr 9, 2015 04:28 PM
bocho214
Jan 29, 2015 09:19 AM
