BD-Power Steering Stabilizer
Old Oct 13, 2010 | 09:32 PM
B Boyce's Avatar
Default BD-Power Steering Stabilizer
I got a 98 dodge ram and i have always had a lot of wobble and steering wander, and i seen on extreame diesel that BD power has a dodge steering stabilizer. So i was just wondering if any of you guys have purchased this and if it helped at all?
Old Oct 13, 2010 | 11:10 PM
Lil Red Express's Avatar
I have never used one but have heard nothing but good about them.
Old Oct 14, 2010 | 05:47 AM
ztk7220's Avatar
i had the death wobble and i got the sbs and it did not fix it the i got a track bar and that fixed it but i have oversized tires and it still pulls me from side to side
Old Oct 14, 2010 | 09:40 AM
Default Re: BD-Power Steering Stabilizer
My 01 was doing the same. I replaced the Ball Joints, Rebuilt the Track Bar and had the Steering Stablizer. It fixed 99% of my steering issues.
Sent from my Rooted Droid 2.
Old Oct 14, 2010 | 12:30 PM
44'snot24's's Avatar
stabilizers fixed the majority of my death wobble i had on my truck still need a track bar but its nothing to what it used to be only a little bit every once in awhile
Old Oct 14, 2010 | 12:46 PM
steel's Avatar
Dont waste ur money. Keep a close eye on the drag link and the torsion bar. i have 1 and it didnt help unless u want more wieght up front.
Old Dec 13, 2010 | 11:13 PM
mike_cummins's Avatar
@ztk7220 i put on the 08+steering assembly and a carli suspension high mount steering stab and it will correct the pull to the right and it helped with the wobble but i still have it, i have a adjustable track bar that i havent put it on yet because i need bushings with a 5/8 hole and mine have a 1/2 inch hole and im still gona put a dual steering stab on it to so that way i will have a triple stabilizer setup i also want to do the steering box brace as well and hopefully this will correct it...any suggestions or tips are greatly appreciated...
Old Dec 19, 2010 | 09:27 PM
jc3835's Avatar
I just had one installed last Monday, and it made a helluva difference on mine; less slop, LOT less wobble on expansion joints and the like.
It was just the latest step in upgrading the entire front end.
I've now done the steering upgrade (from Source,) Bilstein stabilizer, new suspension (KORE HP,) track bar bushing upgrade, MAXXlinks sway bar links. Next is upper and lower ball joints, as I'm at 82K miles with the stock ball joints.
Put the new tire/wheel combo on this August, and it's bringing the stock deficiencies to light pretty quickly.
Old Dec 21, 2010 | 01:25 AM
Uncle Bubba's Avatar
Check out the thread linked in my signature to learn about a lot of this issue.
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
