Lift Pump
Old Oct 3, 2010 | 08:02 PM
zbructo's Avatar
Default Lift Pump
What is a good lift pump for a 2001 Duramax LB7 and is it worth it if I only want to make 400 to 500 hp.
Old Oct 3, 2010 | 09:16 PM
wildbill's Avatar
There are 2 that I can think of right off the top of my head, Airdog and FASS.
Old Oct 4, 2010 | 09:50 AM
bftrain's Avatar
Like kit or plumb in yourself? I plumbed in a 10 psi walbro FRB-5 followed by a high eff filter base from napa and it works great. I spent less than $140. My max tune is between 400-500hp.
Also it is so much quieter than a fass or airdog. You can hear it clicking when parked at idle but my engine drowns it out when I take off.
It is a flow through design as well in case it ever does fail it won't leave you stranded.
A down side is that it is 1/4 npt, but I used stainless fittings and drilled them out to the same size as the heavy wall tubing I plumbed it in with. IMO it shouldn't matter while the pump is working. It is capable of flowing 60 GPH.
Old Oct 4, 2010 | 02:56 PM
2500HeavyDuty's Avatar
the airdog 165 is a easy install, but a pusher pump like a raptor or the small fass works quite well.
HeavyChevy95
Dec 21, 2016 10:36 PM
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
