Airdog 165 problem
Old Sep 20, 2010 | 12:24 PM
promodcummins's Avatar
Default Airdog 165 problem
I just got my AirDog 165 about a month ago. Pressure was factory set at 17 psi. Now all of a sudden my pressure is at 30 psi. I checked the pressure regulator and jam nut is tight. I then loosened it and turned counter clockwise 1 turn, pressure went down to 28 psi, I then went another full turn with no change. Im thinking its either the pump regulator or the fuel pressure gauge. Either way, can I hurt my cp3 injection pump running motor at 30 psi, lift pump pressure. Thanks
Old Sep 20, 2010 | 02:47 PM
sidekick's Avatar
i belive the relieve valve should open if needed and return fuel so it doesent hurt anything
Old Sep 21, 2010 | 01:23 AM
I called the tech at AirDog named Ryan and he put me on right track. He told me to back off pressure set screw all the way out , then turn it all the way in which should remove air-air bubble from regulator and reset fuel pressure regulator. Well it worked out for me and the pressure came right back into adjustment. I then set pressure at 19 pounds and rolled some coal on the way home.
burndiesel
10
Feb 7, 2023 01:15 AM
Jake9473
Jul 22, 2018 08:19 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
thurobred1320
May 5, 2015 09:26 PM
