2005 3500 Dually + 265/70R17E = OK or not?
Old Sep 14, 2010 | 01:40 PM
WI Huck's Avatar
FormerVendor
Default 2005 3500 Dually + 265/70R17E = OK or not?
Has anyone tried LT265/70R17E tires on stock 2005 17 x 6.5 inch wheels? I am looking at BFG All Terrain tires and they recommend a 7 inch or larger wheel, but I feel confident that they will fit on the wheel, but I am not sure about the width between the duals in the back. Is there anyone out there running this setup? Do I need a spacer for it to work? I do tow heavy trailers with the truck.
Thanks!
Mark
Old Sep 14, 2010 | 03:08 PM
tiremann9669's Avatar
The problem with running them on too narrow of a wheel is you're deforming the tire and the middle will wear prematurely.
Old Sep 14, 2010 | 09:05 PM
WI Huck's Avatar
FormerVendor
Yea, I know, but the tire is rated for only 0.5 inches more. I know that there are people going way outside the recommendations and getting away with it. I am just frusterated that there is such a limited number of tires available and I want it to look tougher than what the stock tires look like.
Old Sep 14, 2010 | 11:01 PM
So buy wider wheels, Alcoa's are nice
What size are the stock tires ?
Last edited by tiremann9669; Sep 14, 2010 at 11:01 PM. Reason: Automerged Doublepost
Old Sep 15, 2010 | 08:10 AM
WI Huck's Avatar
FormerVendor
I can't find any wider wheels. Bolt Pattern = 8-165. A 17x7 would be fine. The original tire size is 235/80-17.
Old Sep 15, 2010 | 12:12 PM
That sucks must be inside clearance keeps manufacturers from making wider rims. A 255 tire recomends a 6.5 -8 inch rim so I guess one more centimeter wouldn't make a world of difference
Old Sep 17, 2010 | 06:53 AM
WI Huck's Avatar
FormerVendor
I decided to go with the 245's instead. Thanks for the help!
May 7, 2015 02:50 PM
krackerjacklee
Mar 2, 2015 02:34 PM
Glennvd44
Dec 20, 2014 04:02 PM
Walker.B
Dec 12, 2014 12:04 AM
ironforger
Wanted To Buy (WTB) - Used
Nov 17, 2014 10:25 AM
