89 Ford 7.3 Cold Start problems other threads do not cover
Old Aug 4, 2010 | 10:30 PM
DieselX's Avatar
Default 89 Ford 7.3 Cold Start problems other threads do not cover
Hi all,
Lots of good information on this site about a hard cold start but still no success for this Ford.
The problem:
Hard cold start, excellent performance thereafter including restarts, however, the longer it has been since turned off the more cranking to start. First start of the day requires a shot of ether.
I have checked the glow plugs as many have suggested in other threads and all are up to specs
The batteries are strong
I cannot detect any air leaks pre-filter but there is a slight bubbling coming from a return line o-ring at one of the injectors, could this be the problem? Is there anything that I am missing?
Thanks in advance, there is a lot of great information here looking forward to a reliable start every morning,
Charlie
Old Aug 5, 2010 | 01:10 PM
Budgreen's Avatar
Originally Posted by DieselX
Hi all,
The problem:
Charlie
That my good friend becomes an air leak once the motor is shut off. I bet if you put on new o-rings and return lines all will work as expected.
Old Aug 5, 2010 | 07:47 PM
DieselX's Avatar
Thank you, I ordered a kit this afternoon.
Charlie
Bigredpowerstroke
Aug 14, 2015 10:31 AM
cjgregory
Mar 31, 2015 01:45 PM
makuloco2000
Feb 15, 2015 02:31 PM
custom7.3
Nov 23, 2014 10:44 PM
7.3stroke
Oct 27, 2014 06:25 PM
