Locked Up????
Old Jul 16, 2010 | 10:47 PM
Casefarmer's Avatar
Default Locked Up????
Hey got a question bout motor lockin up. It was idling and then i went pop and died. I tried to turn it with a ratchet but no luck? Could it be locked??? Any help would be great
Old Jul 17, 2010 | 04:41 PM
lil red's Avatar
little more info would help what engine what kind of veh. does the oil stink ect.
Old Jul 19, 2010 | 09:11 PM
Casefarmer's Avatar
its a 98 12 valve. no has oil in anit-freeze. so wat a head gasket, or head is wat i thinkin.
Old Jul 21, 2010 | 11:58 AM
lil red's Avatar
might pull injector's and inspect for signs of coolant if so kinda sounds as though your on the right track. if no signs try loosening all rocker's so no valve actuation and see if it turns. good luck hope its not worse than H G
Old Jul 27, 2010 | 07:31 PM
xTakk's Avatar
B-series cummins like to lose injectors, in my opinion, your best bet to get you started if you think your engine may be locked up is to find a mechanic that has access to a bore scope and check to see that all pistons will pass a quick visual inspection, Pulling the head will accomplish this also but at the cost of a headgasket and a few beads of sweat. If all of your pistons appear to be in functional condition, you may be able to find metal particles in your oilpan, possibly only by draining your oil, or by completely dropping the pan and checking for any more serious problems that may have come from weakened fasteners or oil starvation.
In short, if the motor will not rotate at all manually, I tend to think the worst. Check your oil/pan for metal of any sort, if you can drop the pan, you can visually spot any type of rod or fastener issues, and can see how much play there are in the rod caps to check for some bearing issues.
Any more information you can find out would be helpful, I will check back here soon.
Old Jul 27, 2010 | 07:38 PM
BlackCloud96's Avatar
Is this the truck you just bought? If so you got hosed i would take that truck and stick it in his
Old Jul 27, 2010 | 07:39 PM
Red_Rattler's Avatar
High Tech Redneck
Yes it is and yes he did....
Old Jul 27, 2010 | 09:51 PM
Casefarmer's Avatar
Yea it is and i had a buddy pull it once and then this happened but its all good. My buddy wanted in on it wit me so he talked to his mom and dad and were prob goin to rebuild and start from new
Old Jul 27, 2010 | 10:01 PM
High Tech Redneck
I hope you stay froends Up here theres 2 bros that went half and half on a 1200hp dmax puller and now they are fighting over whos it is and who has more into it and what the other has to pay to buy them out, its a big mess needless to say...
Old Jul 29, 2010 | 03:46 PM
Sideshow's Avatar
I have run across 12 valves in the past that had pumps replaced and the nut over tightened causing a break in the drive gear locking up the eng causing the crank gear to shear the dowel pin throwing timing off don't know if that is your problem but worth checking out just pull out the oil fill and look for anything out of place
cumminspwr11
12
Oct 17, 2021 03:50 AM
cummins1999
Jun 26, 2015 01:56 AM
twwtruck
19
Apr 7, 2015 05:14 PM
bajahigh
Dec 9, 2014 03:46 PM
