batteries dead
I had my batteries die on me to I recharged them on 6amp which took about 24 hrs a piece. Tried to start truck and ran fine. Less then a week later, same thing, batteries dead. Rechanged again, disconnected my amp for the radio and Now a code P2509 (ECM/PCM power Imput Signal Intermittent). Further, now my horn goes on and off at will. I had to find a new horn as the old one had gotten a hole in it. Any help would be appreciated as I need my truck to work correctly. Thanks
Yeah more than likely you either have a dead cell in a battery which will kill both when sitting idle. Or you have a faulty alternator that is not putting out enough voltage to charge the batteries.
Make sure if it is the batteries that you have the alternator checked also. Sometimes a bad battery will also hurt or fry an alternator in the process.
burndiesel
10
Feb 7, 2023 01:15 AM
greasesheik
Apr 9, 2015 09:33 PM
mpcampers
Dec 4, 2014 08:24 PM
12vlejeune
Nov 19, 2014 05:39 PM
