1999 dodge 4x4 brake issues
Old Jun 20, 2010 | 08:58 PM
TJREX's Avatar
Default 1999 dodge 4x4 brake issues
Ok....I just replaced my brakes pads and a rotor up front along with installing the gm upgrade in the rear.
The brakes work fine but now I have the red "Brake" light lit on my dash as well as the yellow abs light....I dont have ABS.
any ideas? I ran odb2 and it show no codes.
Old Jun 23, 2010 | 09:31 AM
lil red's Avatar
Could poss. be a bad wheel speed sensor front sensor resistance should be 945/1155 and rear 1600/2300 ohms if not then need to be replaced why all of a sudden ? rears are pretty common also jumper wire
Old Jun 23, 2010 | 09:52 AM
12vcummins96's Avatar
hmmmmm thats wierd i would check the sensor in the rear diff its a culprit
it gets dirty and will not read
Old Jun 23, 2010 | 02:33 PM
lil red's Avatar
I agree with 12vcummins might also add that year truck with man. trans and rear wheel ABS speedo will not work either.
Old Jun 24, 2010 | 05:58 PM
TJREX's Avatar
have not got a chance to try and fix this yet but did notice the speedometer stays at zero until I hit 25 mph and then jumps right to 25....go below 20 and it jumps to 0 mph....must be the speed sensor on the rear dif
Crwln73
Jun 24, 2015 05:14 PM
PeteBug
Jun 11, 2015 12:16 PM
oilfieldguy
Feb 9, 2015 07:42 AM
Mat Zimmerman
Dec 8, 2014 11:37 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
