limped then wouldnt move..
Old Jun 16, 2010 | 07:14 PM
MI-Duramax-Boy's Avatar
Default limped then wouldnt move..
took off in my 01 duramax today, and it instantly trans limped for some reason,...
just did spin on 2 days ago.
pulled over and shut the truck off to let it reset. then it wouldn't move in any gear.... the gear indicator would just flash on each gear..
only way i got it goin again was disconnecting batteries.
took off fine after that and a mile down the road the codes turned themselves off???
went on a 100 mile round trip right after and had no problems..
and ideas?
neutral safety?
Old Jun 16, 2010 | 11:50 PM
2500HeavyDuty's Avatar
you probably have a transmission code, some thing happened to me when the nsbu switch went out on my truck after i took it mudding
Old Jun 17, 2010 | 12:54 PM
thats what i was thinking. couldnt figure out what else would have made it limp as i was on level three on the juice and have a triple-lok.
ok read codes at work today and got P0847 Trans fuild pressure sensor B. and 2 pending p0700 trans control..
anyone help me with what the next step should be?
Last edited by MI-Duramax-Boy; Jun 17, 2010 at 12:54 PM. Reason: Automerged Doublepost
Old Jun 18, 2010 | 02:14 AM
EvilBowtie's Avatar
what kind of spin-on filter did you use?
Did you do an internal as well?
Possible - incorrect filter used for the spin-on. Possible - internal filter not properly installed or fell out a little. ( i know you just mentioned spin-on but figured this would help as well)
Hows the fluid level ?
Old Jun 18, 2010 | 10:54 AM
from the code, ur orbbaly have dirt or contaminants in the trans causing a stuck valve, but wont know yet.
x2 on fluid level
Old Jun 18, 2010 | 12:53 PM
no did not do the internal..
spin on was a champion Labs.
went on perfect, no leaks anywhere.
fluid level looks fine...
think i should drain it and do an internal now also?
ASarsano
Ford Powerstroke 2011-Up 6.7L
18
Dec 14, 2015 12:54 PM
Walker.B
8
Nov 12, 2015 09:00 PM
twwtruck
19
Apr 7, 2015 05:14 PM
cdpowers
Jan 23, 2015 01:42 PM
