Boost?
Old Jun 9, 2010 | 04:09 PM
BRE's Avatar
BRE
Default Boost?
OK i used the search function and cannot find anything... I got tired of looking and so i figured i would ask. I have a 94 5speed with 5inch exhaust, custom plate, custom air filter set up. I still have the ole' Wh1c turbo and was wondering what you guys thought was to much boost. I know on the hx35 its 32-35 for longevity. Is the Wh1c any different?
Old Jun 9, 2010 | 06:17 PM
tltruckparts's Avatar
i think 35-37 or so would be about the limits
Old Jun 9, 2010 | 06:22 PM
wes-cummins's Avatar
it will befine to run it up to 35-40 but it is just going to be pumping hot air in your engine
Old Jun 9, 2010 | 09:49 PM
94 12valve's Avatar
32 is all the harder you should push that wh1c
Old Jun 10, 2010 | 07:53 AM
BRE's Avatar
BRE
Ok thanks guys! i just didnt know where the drive pressure started taking over... didnt wanna ruin things
Old Jun 10, 2010 | 09:15 AM
94 12valve's Avatar
your drive pressure will depend on your wastegate and exhaust housing size. You will need to plumb a guage into your exhaust manifold to check and tune your drive pressure.
The goal is to get 1psi of boost for 1psi of drive.
Old Jun 11, 2010 | 08:01 AM
BRE's Avatar
BRE
Ok! Thanks 94 12valve
Old Jun 11, 2010 | 09:10 AM
coalrollin12v's Avatar
whas drive pressure?
Old Jun 11, 2010 | 11:03 AM
94 12valve's Avatar
drive pressure is the pressure comming out of the exhaust manifold that drives the turbine wheel. if your drive pressure is too high it works just like an exhaust brake
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
Crews8r
Dec 21, 2014 07:35 AM
