2003 Cummins cutting out
Old May 21, 2010 | 04:53 PM
wyoranch's Avatar
Default 2003 Cummins cutting out
Hey guys, my '03 started cutting out last week. Sometimes when i start it it will die or almost die after running 5 seconds or so. Now it has started getting dead pedal. Im getting 2121 and 2122, also the code for the SKIM not in key, forget the number. I assume that one is the chip in my key is going bad? Anyway, ive cleaned the connections on the injector harnesses and apps, cleaned almost every connection i can find. I assume its the APPS, but for $400 i wanna be sure. Is there a procedure on testing the apps? This is an early '03, the apps is on the engine, not under the battery (i learned after tearing out the battery, inner fender, etc
Old May 22, 2010 | 02:38 PM
dieseldude03's Avatar
The cutting out and dying sure sounds like a bad lift pump. What is your fuel pressure?
Old May 23, 2010 | 01:12 PM
wyoranch's Avatar
I replaced the factory lift pump with an upgraded external pump 6 months ago. Don't have a gauge. It acted like this when the pump was bad, but that doesn't explain the codes or check engine light. I'm pretty sure it's a bad connection or apps
I read of people testing their apps to see if it's good, I know Simone has to have a procedure...
Aug 13, 2015 11:50 AM
Dertyd
24
Jun 7, 2015 02:45 PM
Mopar92
Mar 11, 2015 09:17 PM
elkmaniac
Oct 29, 2014 07:01 PM
dieseldude03
For Sale
Oct 2, 2014 07:53 AM
