Good Place To Set Timing
Old Sep 23, 2007 | 04:49 PM
Cumminsdieselboy's Avatar
Default Good Place To Set Timing
I am in need of a timing adjustment and i am getting it done tuesday, but i am wondering what should i get it set at? buddy of mine has his at 15.5* and runs good i was thinking 16. Just wanted to see what ya'll think.
the reason i need timing is when cold (80* or colder), i cant take it above 1500rpm with out it missing and blowing white smoke, but once warm i had no troubles. also now sometimes it even does it when warm, not anywhere as bad. the truck has 294,000 miles i figure it is due for timing anyhow. Also it cranks over 2-3 seconds before firing(hot or cold). I figured that can be the only thing is timing, i got a FP gauge, new lift pump, new overflow valve, new injectors, 3K kit and a 0 plate. but what is really weird when warm it idles at 950, if i give it a little fuel before hitting the key it will fire almost instantly, so its not a fuel supply issue.
What do ya'll think.
thanks in advance.
Cody
i know someone knows what to set it at. I need to know tomorrow becuase it is going in tomorrow night, so i wanted to post earlier, so i knew.
Thanks
Last edited by Cumminsdieselboy; Sep 23, 2007 at 04:49 PM. Reason: Automerged Doublepost
Old Sep 23, 2007 | 06:02 PM
Heath's Avatar
Authorized Amsoil Dealer
I was thinking of boosting mine up as well. I'm at 14 now and am getting the pump rebuilt and didn't know whether to stay a 14 or try for 15. ?
Old Sep 23, 2007 | 09:03 PM
15-16 degrees is a good place to start...
Make damn sure that the shaft is clean from oil.grease before torquing the nut down (use some brake cleaner to clean it).
http://www.piersdiesel.com/TechPTiming.htm
Old Oct 6, 2007 | 06:59 PM
Monster Truck's Avatar
How easy is it to change the timeing your self? how much does it usually run to have a shop do it?
Old Oct 6, 2007 | 09:33 PM
MnTom's Avatar
With the right tools the timing is fairly easy to do. I reset the timing on mine myself, but that was about 5 years ago....... Like Doc says, keep the pump shaft and gear clean. Any oil or residue from a cleaner can allow it to slip again. Also make sure that you torque the nut to 160 ft/lbs. BTW, most people seem to shoot for 16*.
Tom
quiksilver1j
Jul 30, 2015 12:41 PM
jkidd
For Sale
Dec 9, 2014 12:33 PM
jkidd
Diesel Auto Power
Dec 9, 2014 12:16 PM
SMatyac
Nov 15, 2014 07:35 PM
jjbced
Oct 26, 2014 09:09 PM
