96 vs. 03 7.3
Old May 5, 2010 | 09:44 AM
jasonp957's Avatar
Default 96 vs. 03 7.3
Ok, I have a 2003 7.3L CC 4x4 with 6637 intake, 4 to 5 inch stright pipe, 35x12.50 tires. Egt's are fine and boost reaches 16 psi when I get on it. Transmission doesn't seem to have any issues, new fuel filter, and fresh oil change. Should my Brother's 96 ext cab stock with 33 x 12.50" tires be able to run with my truck? I seem to be lacking power. I have never heard another 7.3 with the stright pipe and it seems to be fluttery sounding (don't really know how to describe). I don't know if it runs fine or I just expect too much without a chip. The MPG seem to be fine at around 14-15 in city. Any info is appricated.
Old May 5, 2010 | 11:11 AM
12vcummins96's Avatar
your expecting to much imo a chip is a big factor
Old May 5, 2010 | 01:06 PM
CSIPSD's Avatar
Both trucks stock, you should pull him... Differance is tires. You have larger tires which puts you at a disadvantage. His truck is also about 1500# less then yours.
Old May 5, 2010 | 01:26 PM
jasonp957's Avatar
Default ???
Thanks,
I didn't know if I should have had much of an advantage with the newer generation 7.3 . I really didn't have a clue.
Old May 5, 2010 | 05:31 PM
CSIPSD's Avatar
You have bigger injectors and a smaller turbo housing. You should pull him, but your truck weighs about 1500 pounds more, and has larger tires...
Browe347
Dec 11, 2016 02:59 PM
Toms73
Mar 23, 2015 08:31 PM
tumble72
8
Nov 27, 2014 10:31 PM
Altonlee
9
Oct 8, 2014 02:31 PM
Browe347
Sep 30, 2014 11:35 PM
