wheel vibration
Old May 3, 2010 | 03:44 PM
skyjacked84's Avatar
Default wheel vibration
got a 2500 07.5 with 44k. used as a farm/ dd what would cause the steering wheel and cup holders vibrate. tires dont show signs of ware. slight clicking sound every now and again.
Old May 3, 2010 | 06:19 PM
BLACK RHINO's Avatar
Any slack in the steering? To suggest A tie rod end or something of that nature. Or could be as simple as mud in the rims. Hardly ever like washing the rims on my dually cause you never get it all out and the sucker vibrates like A mother when you miss some. Got to be my number one most hated thing about running the dually... Just about got to take the tires off to get them clean. Other thing I would suggest is lifting the nose in the air and spinning the tires sometimes A separating tire is not as obvious as one might think.. Hope this helps.
Rhino.
Old May 3, 2010 | 11:38 PM
lunk's Avatar
my did that end up being the drive shaft u-joints i had the clicking too,my had 60,000 miles. i even bought the front hub u-joints cause i thought the clicking was coming from the front.
Old May 4, 2010 | 11:39 PM
FarmDiesel's Avatar
Im not sure but I thought there was a recall with the tie rod connections or something... The dealer mentioned it to me when I was there one day.
http://www.internetautoguide.com/aut...500/index.html
Old May 5, 2010 | 12:00 AM
ETXBlueRam's Avatar
You might also pull the front drive shaft, then drive the truck. If it still vibrates, you can eliminate the driveshaft from the problem list. Inspect the driveshaft for dings/dents also. That can throw it out of balance.
cutthroatxxx
Jun 22, 2015 10:16 PM
6.5dieselman
Feb 26, 2015 04:45 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
findau1
Oct 28, 2014 03:47 PM
findau1
Oct 27, 2014 09:10 AM
