48RE rebuilt trans problems, please help asap
Old Apr 29, 2010 | 09:32 AM
CumminsTurbo22's Avatar
ATTN 48RE rebuilt trans problems, please help asap
its for my 04, trans was rebuilt and it worked fine, was going down a bumpy road and all of sudden i only have reverese, 1st and 3rd. Seems to me like something electrical, we scanned it but no codes. Does this sound like a bad governor? or mabye the tcm craped out? before i blew the trans it only had reverse and 1st gear, The valve body was not replaced but was added a shift kit. Any suggestions? Its too cold to keep riding my motorcycle to work.
Old May 2, 2010 | 09:53 AM
Diesel Nut's Avatar
Check all the wiring for the transmission, including where it heads up into the engine compartment. There is a plate on the transmission on the drivers side where the wring harness is mounted. Check everything really well for loose connectors, chaffed wires, or broken wires. Also, if you can get a code reader that will read live data that would be a huge help.
Kfohne21
10
May 12, 2022 10:13 AM
Jake9473
Jul 22, 2018 08:19 AM
yfzrunner
Feb 7, 2015 10:52 PM
97boatstroke
Oct 28, 2014 01:58 AM
