white smoke
Old Apr 25, 2010 | 06:43 PM
jimmyd's Avatar
Question white smoke
white smoke no power smoke clears runs a bit better until it warms up then stalls let it cool starts rite up heavy white smoke runs good down hill only
Old Apr 25, 2010 | 06:50 PM
Red_Rattler's Avatar
High Tech Redneck
Sounds like the injection pump is outa time. Also look for any fuel leaks and check the fuel pressure. But it sounds like a timing issue since those were (some) of the symtoms my 95 had.
Old Apr 25, 2010 | 08:19 PM
Diesel Nut's Avatar
Either the timing slipped, you have a leak or restriction on the suction side of the lift pump, or you have a stuck plungerin one of the barrels. After it stalls is it a royal pita to start?
Old Apr 26, 2010 | 07:50 AM
jimmyd's Avatar
not if i let it cool few minutes
starts then run ok till temp goes back up would a head gasket do this
Old May 5, 2010 | 01:04 AM
swinter0322's Avatar
I have an 06 f 350 and my did the same thing had white smoke and then no power it was my head gaskets
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
