gear ratio
Old Mar 6, 2010 | 01:14 AM
redneck817's Avatar
Default gear ratio
How do i figure out what my gear ratio is without having to remove the diff cover? Im trying to figure out what Im running so i can figure out a way to get better mpg and get away from 2500 rpm at 70mph. My truck has a 7.3 with a 5speed sittin on 265s.
Old Mar 6, 2010 | 08:16 AM
CARP's Avatar
I'm assuming you have 4.10 gears. Alot of those 7.3's were geared lower for pulling. Especially with the 5 speed.
Old Mar 6, 2010 | 10:23 AM
DieselCrawler's Avatar
on the diff over should be a little tag with a bunch of numbers on it. probly rusty, but it will say on the second line the first 3 numbers will be gear ratio
will either be 3.55 or 4.10
Old Mar 6, 2010 | 10:34 AM
PSD's Avatar
PSD
It might also say in the door jam
Old Mar 6, 2010 | 12:45 PM
redneck817's Avatar
no tag on rear axle and the door jam just says its a C5 axle
Old Mar 6, 2010 | 02:29 PM
PSD's Avatar
PSD
That code should be 4:10 limited slip
Old Mar 6, 2010 | 04:29 PM
redneck817's Avatar
ok found the tag (never let brother-n-law look at truck) first three numbers are L10 so does that mean it has 4.10s in it
Old Mar 6, 2010 | 04:38 PM
PSD's Avatar
PSD
Ive seen 4L10
Old Mar 6, 2010 | 04:43 PM
redneck817's Avatar
all i saw was the L10 have to scrap off a lil bit more to see if there is a 4 or not
it says 4L10
Old Mar 6, 2010 | 07:02 PM
CARP's Avatar
Yes. C5 axle code is a 4.10 limited slip axle.
