Play in Steering
Old Mar 4, 2010 | 08:18 AM
dmaxtothemax's Avatar
Default Play in Steering
I've got a 2001 GMC Sierra Duramax 2500HD with 8" lift... My problem is the steering is very loose... I can drive straight down the road and it will pull left - i correct - it pulls right - i correct, and so on (looks like i'm tipsy)... When parking in parking lots, it feels like one wheel turning and the other taking it's time... I had the wheels off one day and noticed some links that appeared loose, but I know nothing about lifts/suspensions... I was hoping someone would know what to check or do to fix the problem... Thanks
Old Mar 4, 2010 | 12:21 PM
FastCR's Avatar
balljoints, tie rods, and pitman and idler arms. Lifted GM will eat through all of them, its pretty standard to have to go through them often.
Old Oct 27, 2010 | 10:41 PM
Just to update...
Changed Pitman, Idler, Tie Rods/ends... Problem 95% solved... Will change ball joints next chance i get...
Old Oct 28, 2010 | 12:06 AM
TruePerformanceDiesel's Avatar
FormerVendor
There is an adjustment on the steering box to take the slop out of the gears. I just did that on a 02 & 05. Fixed it with no play.
Old Oct 28, 2010 | 12:16 AM
very cool... i will investigate and see what i can do... Thanks buddy
Antwhite19
Aug 23, 2015 06:07 AM
crpmap
Ford Powerstroke 08-10 6.4L
Jun 17, 2015 10:36 AM
ramrunner01
Jun 1, 2015 12:10 AM
BubbaDT55
Apr 12, 2015 10:47 PM
sweetv8s10
Oct 7, 2014 09:47 PM
