KDP question
Old Feb 26, 2010 | 10:17 AM
markp's Avatar
Default KDP question
We've all heard discussions on the "killer dowel pin", and how to fix it, and what happens if you don't. I was told by a "reputable" and well known cummins mechanic in my area that I didn't have to worry about it in the 1990 5.9 Cummins that I have.
I read Field Notification # E03003 and it sounds like it is only on P7100 pump engines.
Anyone know for sure?? Better safe than sorry for me. I've seen pics of the damage.
Old Feb 26, 2010 | 11:28 AM
Pyro690's Avatar
All 12V and 24V till 2001 and some after 2001.
Old Feb 26, 2010 | 01:17 PM
markp's Avatar
Here is a copy of the Field Notification on the KDP:
Early Field Notification Number Revision Level Date
E03003 23-JAN-2003
Engine Family Fuel System
6B, B5.9 Bosch P Pumps
Design Application Market Application
All All
Gear Housing or Gear Damage Prevention
Summary of the Early Field Notification
-This document outlines the procedure for correcting and preventing the gear housing locating dowel pin from falling out of the gear housing, possibly resulting in gear housing and/or gear train damage.
Affected Engines
-This problem has only been observed on 6B engines built prior to June 1998 equipped with the Bosch P7100 fuel pump.
Symptoms and Observations
-The following procedure is recommended if a 6B engine with Bosch P7100, inline, fuel injection pump built before June 1998, has the front gear cover removed for any reason. In 1998 the gear housing casting was changed so that the locating dowel pin could not fall out of the housing.
Failure Verification
-Not Applicable
Suspected Cause
-Not Applicable
Potential Component Damage Assessment
-Not Applicable
Repair Instructions
-NOTE: Two versions of the gear housing exist. One version has a raised boss around the dowel hole. The second does not have the boss. Refer to the appropriate corresponding procedure.
Bossed Gear Housing
0. Push dowel pin back into dowel hole.
1. Use a punch to stake the inside of the dowel pin hole so that the created bur prevents the dowel pin from moving in the gear housing.
2. Re-torque all accessible gear housing capscrews to 24 N•m [18 ft-lb].
NOTE: It may be necessary to bar the engine to gain access to the capscrews located behind the cam gear.
Non-bossed Gear Housing
0. Remove the gear housing mounting capscrew located directly adjacent to the locating dowel pin.
1. Install the tabbed waster, part number 3958017, so that the tab covers the dowel pin hole in the housing.
2. Torque the capscrew to 24 N•m [18 ft-lb].
3. Re-torque all accessible gear housing capscrews to 24 N•m [18 ft-lb].
Old Feb 26, 2010 | 05:20 PM
tltruckparts's Avatar
the early 12valves are just as likely to have them come out as a p pump. i tabbed mine
Old Dec 11, 2012 | 01:56 AM
gunman41mag's Avatar
Moderator
this is what can happened
Old Dec 11, 2012 | 10:06 AM
Moderator
How many engines have been damaged by the KDP ???
Old Dec 11, 2012 | 03:55 PM
tiremann9669's Avatar
Can happened .......You really need to learn the English language
Last edited by tiremann9669; Dec 11, 2012 at 03:55 PM. Reason: Automerged Doublepost
51Hudson
10
Aug 5, 2015 12:32 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
countryboy040993
Dec 31, 2014 05:10 PM
xj_crawler
Nov 20, 2014 12:28 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
