2000 7.3 fuel pressure?
Old Feb 19, 2010 | 11:31 PM
77scoutracer's Avatar
Default 2000 7.3 fuel pressure?
Where is the best place to check fuel pump on a 2000 7.3? What should the pressure be right after stock pump?
Old Feb 19, 2010 | 11:45 PM
ArizonaRedneck's Avatar
check this out and see if it has the right info for you https://www.dieselbombers.com/ford-p...ure-gauge.html
Old Feb 19, 2010 | 11:59 PM
Thanks man!
Old Feb 20, 2010 | 07:20 AM
CSIPSD's Avatar
Fuel pressure on a Superduty should be between 55-70 at the Fuel bowl. OBS trucks can run slightly less due to the mechanical pump.
Old Feb 21, 2010 | 09:44 AM
guzzle's Avatar
Keep in mind that an underhood gauge will be of limited use. It will not diagnose a bad pump as you could also have a problem with a cracked or worn seat on the Fuel Bowl Relief valve.
Even with good fuel pressure at an idle while sitting in your driveway, it could be totally different when pulling a trailer up a grade.
An in cab electronic fuel gauge is the only way you will be able to determine if you fuel delivery system is performing properly under various load conditions.
Old Feb 21, 2010 | 01:24 PM
CSIPSD's Avatar
100% correct... Its a good cheap starting test but will not tell you everything!
I can drop my fuel pressure from 65 to 20psi on a WOT run right now with a factory pump that is slowly failing...
Old Aug 11, 2014 | 06:35 PM
bestrada11's Avatar
I have a FASS pump. Just got 160/80's installed. was told to set pressure at 65psi.
Fass pump only goes to 55psi, I called fass they said to shim the return line to achieve 70psi pump return then set the fuel supply regulator to 65. problems I have been having are lopey idle
lots of black smoke and high egts'
do you think this could be the culprit?
Old Aug 11, 2014 | 08:45 PM
joebob3093's Avatar
Moderator
Did you get your chip reburned after you installed the injectors?
Old Aug 18, 2014 | 09:26 AM
bestrada11's Avatar
Yep new tunes from dp
Excursion73
Sep 17, 2015 11:46 PM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
