2000 powerstroke 7.3 misfire or sputter
Old Feb 18, 2010 | 06:49 PM
hvacman001's Avatar
Default 2000 powerstroke 7.3 misfire or sputter
7.3 2000 F350 Driving down the road at any speed and the truck acts like it misfires or sputters but does do it as hard or as much once truck is warmer any sugestions
Old Feb 19, 2010 | 03:27 PM
mcdowell's Avatar
im haveing the same problem on my f450 but when it warms up it still does it. does yours die on you while driving
Old Feb 22, 2010 | 08:06 PM
Diesel Nut's Avatar
We have an 02 in right now for similar issues. Cold it lopes and stumbles. Overall power is down. We removed the Edge Juice w/Attitude and things got better, but its still not right. In the morning we are going to check fuel pressure from the lift pump. Also, we set a code for #2 contribution fault, so could have an injector heading south. ICP seemed to be normal. Hope this helps.
Old Feb 23, 2010 | 09:54 AM
oldblue05's Avatar
I had a similar problem with my 1990 idi just a few weeks ago, there was a crack in one of the fuel lines in the return line system that goes from injector to injector. The trucks yall mentioned are much newer but could possibly suffer from the same issue. I pulled the line off at the injector pump, turned my air compressor down to about 15 psi and pressurized the return line system, then replaced the hose that had diesel leaking out.
Excursion73
Oct 27, 2015 05:21 PM
Excursion73
Sep 17, 2015 11:46 PM
fivo2fst4u
Jul 2, 2015 06:20 PM
Locoster
Jun 22, 2015 10:54 AM
racinfast002
For Sale
Jan 7, 2015 12:46 PM
