n14 celect cummins 525hp
Old Feb 8, 2010 | 12:31 PM
GWILLIAMS's Avatar
Default n14 celect cummins 525hp
need to know how to set overhead and torques for rocker bridge and injector adjustment on a n14 celect cummins, also jake bridge torque engine serial number 11998974 525 hp
Old Feb 8, 2010 | 03:33 PM
ArizonaRedneck's Avatar
On the Celect,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you hand tighten screw until injector plunger bottoms out.Back screw out 2 flats,ie turn corner of lock nut to align with the riviot in the rocker lever(pushtube side),then back out screw two "corners" then tighten the jam nut down.Adjust the Injector first,then the valves. The C Brakes lash is 0.023.
looked around and found this hope it might help and welcome to diesel bombers
Old Feb 8, 2010 | 04:14 PM
nice...
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Oct 20, 2014 08:10 AM
