6.5L Diesel chevy as a DD...couple of ?'s
Old Feb 8, 2010 | 12:18 AM
cummins freak's Avatar
Default 6.5L Diesel chevy as a DD...couple of ?'s
you guys know of any major problems with a chevy 6.5L TD in a '94 1500 this truck doenst look like to bad of a deal for DDing?
How do these ttrucks do in the winter......It would stay 100% stock
http://www.jimstrucks.com/vehicle_pa...6164913-.shtml
Old Feb 8, 2010 | 08:57 PM
birddog531's Avatar
The main thing that can go wrong with these trucks is the PMD (pump mounted driver) which makes the truck either miss or just not run at all. A new pmd cost around $200-$300 (if you shop around you can probably find a better deal) Heath diesel power makes a PMD isolator which elimates the problem of a faulty pmd and moves it near the skid plate under the radiator insted of near the engine where heat can get to it. Heath's isolator costs $549 but is probably worth it. My 97 6.5 hasn't had any major problems since I bought it, theres been a few little things ive fixed but that was expected. It has 93k miles on it now. These trucks arn't bad in the winter as long as you have good battery(s) and plug them in every cold night. The only place you might get in trouble is if you let it sit for more than a few days without running. I think the truck your looking into would make a great DD truck. Alot of people dislike the 6.5's but i think there a great truck. I hope this helps you!
Old Feb 8, 2010 | 10:23 PM
Woody35's Avatar
probably never had injectors so start with replacing that. relocate pmd to inside bumper.pmdcable.com is a lot cheaper than heaths and has good quality parts. oil cooler lines probably need replacing too. pmdcable.com can hook you up with that too.
Old Feb 9, 2010 | 10:05 PM
2MuchJunk's Avatar
PMD like everyone says. I have a 95 6.5 with 296,000 miles on it and none of them where easy. I have replaced the injector pump 1 time 150,000 miles ago, 1 injector, and a couple of pmd's. You can't convince me these are not good engines. If you talk to people that know how to fix them wright they will last forever.
Old Feb 12, 2010 | 11:16 AM
motown's Avatar
i'm new here but i'v had my 6.5 for a long time the only problems i'v ever had witch are common is the pmd oil pressure switch and the lift pump witch are all easy to fix there are also alot of upgrades so u dont have these problems alot i love mine and it's not hard or expensive to make run good mine gets 19.5 mpg and just smoke the tires so far its the best truck i'v ever owned
Old Feb 16, 2010 | 01:04 AM
zach_west's Avatar
my 6.5 was not very good but that might have been due to the fact that it was pretty mistreated too. mine got bout 15 mpgs and the pmd did go out quite a bit. then a wiring harness. then a tcase. but i guess thats every pickup. except my dodge.
Old Feb 16, 2010 | 05:03 AM
moneyman_09's Avatar
my friends truck made it to 103,xxx then blew the head gasket all stock he had a shop replace it all and put new injectors in before a haul to texas he made it there and about 3/4 the way back before it went boom. Had to get out the old farm truck ford haul it and the trailer back to Indiana. it got about 12 mpg with 4.10 gears 2wd
Beeman
15
Jun 27, 2015 06:59 PM
david.burger
May 30, 2015 08:25 AM
MrMoose
Mar 15, 2015 06:05 PM
Fishy816
Jan 11, 2015 08:31 AM
Snoobly
Dec 11, 2014 11:59 AM
