Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
STALLING
Old Jan 31, 2010 | 12:47 PM
cody73's Avatar
Cards STALLING
My dad has a 07 duramax LBZ with banks big hoss bundle you know from intake too tip. about 2 months after I installed it the truck had about 8000miles on it,and under hard acceleration it will stall and the PDA will say low fuel rail pressure. I have heard a couple of people say this is common in a d-max if so how can this problem be solved.
Old Jan 31, 2010 | 01:14 PM
ArizonaRedneck's Avatar
https://www.dieselbombers.com/chevy-...-pressure.html check this out and see if it will help answer your question
Old Jan 31, 2010 | 01:32 PM
2500HeavyDuty's Avatar
well a lbz usually dont need shims, when was the last time the fuel filter was changed
Old Feb 1, 2010 | 03:17 PM
Zecherc's Avatar
My lbz did the same thing, twice actually, when my filter was getting dirty. That was like a year ago and it has never happened since. I changed the filter and that was it. I put shims in anyway and a ported fitting from ppe.
Old Feb 1, 2010 | 04:01 PM
GmcLbz's Avatar
Site Sponsor - Upstate Diesel Performance
As stated above, more than likely a dirty filter. Sometimes it doesn't take much.
Old Feb 6, 2010 | 07:56 PM
cody73's Avatar
this problem has occured constantly for the past 2 1/2 years and the filter has always been changed very regular my dad and I are maintnence finatics. Could it be that the motor is demanding more fuel than the stock pump can supply?
Old Feb 6, 2010 | 09:05 PM
well try adding some shims then and see what itl do. does his pda show you what his rail pressure is?
Old Feb 9, 2010 | 12:40 PM
cody73's Avatar
no it just says low fuel pressure like A scanner would
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
Mike0885
May 27, 2015 12:07 PM
RatsMC
May 4, 2015 05:25 PM
1997silverado
Feb 13, 2015 08:11 AM
1997silverado
Jan 23, 2015 05:06 PM
