Power steering issue...?
Old Jan 24, 2010 | 11:09 AM
64crew4x4's Avatar
Default Power steering issue...?
Hello all....I have a 93 2WD 3/4 Dodge with 12v Cummins and auto...
Here at the beginning of the week, I noticed my P.S. getting very Non responsive....?
When First fired up stone cold there is no PS. if I let it idle and warm up for 5 mins or more
It comes back, but real sluggish.
once I am moving, and Engine is off idle it gets better, but there is the typical PS whine to it....It is full of Fluid, no leaks.....Fluid is old and dirty, so I am going to flush it,
Is there anything else to do, or look for...? One of my local Buds says there May be a Bypass valve in the pressure side of the PS pump not doing its job..? Ie. It is staying open in bypass mode, and not shutting to Go into work mode..? Can this be cleaned, or is it new Pump time..?
Thanks, John
Old Jan 24, 2010 | 12:30 PM
tltruckparts's Avatar
sounds like the pump is just getting weak if it gets better when the fluid warms and at higher rpms. i think my new pump i had to put on was only like 45 bucks it wasnt too bad
Old Jan 24, 2010 | 02:24 PM
gradyc's Avatar
There is a bypass in the pump fitting where the hose hooks to the pump that takes the load off when you are not steering.You can take the hose off and remove the fitting from the pump and clean the parts. After the fitting is removed the valve is behind it with a spring behind that. If cleaning it dosen't help it is probably time for a new pump.
Old Jan 25, 2010 | 09:36 AM
64crew4x4's Avatar
Thanks gradyc......
I'll try that today while I flush the system.
Old Jan 25, 2010 | 10:13 AM
12vcummins96's Avatar
sounds like the pump is getting weak or you are sucking air somewhere check connections and hoses
Old Jan 25, 2010 | 02:33 PM
jasonfriedlin's Avatar
It might have air in it. Look here for some help
https://www.dieselbombers.com/1st-ge...any-ideas.html
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
