24v internals in a 12v block
Old Jan 20, 2010 | 07:01 PM
keithduke01's Avatar
Default 24v internals in a 12v block
What are the differences in a 12v block versus a 24v block. I have a perfectly good 96 12v engine (minus the KDPed case) and a 99 24v truck with the famous cracked 53 block. What would be easier (or even possible) putting the 24v internals into the 12v block or swapping the 24v for the 12v. Any help whatsoever would be greatly appreciated!
Old Jan 20, 2010 | 07:06 PM
Codgedodger's Avatar
FormerVendor
Im pretty sure the heads can swap and you would have to get the injector pop pressure changed for the p7100 injector pump. Not quite sure about everything else.
Old Jan 20, 2010 | 07:26 PM
no no all i need to swap is the 12v block just the bare block. and put the good 24v internals into the 12v block
Old Jan 20, 2010 | 09:10 PM
FormerVendor
O okay I think the blocks are all the same. I do recall someone talking about how some of the gens are the same as the others.
Old Jan 20, 2010 | 09:19 PM
tltruckparts's Avatar
the block is the exact same. the piston dish on a 24 valve is the only difference really in the lower end. as for the block though, everything will go right in
Old Jan 20, 2010 | 09:37 PM
biged681985's Avatar
sorry to tell ya, but u are wrong.
the 12v, at least the 94 model i know for sure doesnt have the right bolt patterns for the motor mounts. and the 12v block doesnt have the port in the side of the block for the crank sensor.
Old Jan 20, 2010 | 09:44 PM
i think it was the 1st gen 12v that was the same as a 24v. but i could be wrong. thats just what someone told me though
Old Feb 15, 2010 | 06:45 PM
SmokeN 12 ValvE's Avatar
The 96 block is not exactly the same as 99. The 96 block does not have the cut out for the crank sensor, as mentioned before the motor mounts are different.
Dayt the great
Aug 16, 2015 07:42 PM
Dayt the great
Jul 22, 2015 01:23 PM
Tory4
For Sale
Feb 1, 2015 08:33 PM
gyayo2012
13
Jan 14, 2015 11:29 AM
Slim Whitey
Nov 8, 2014 09:41 PM
