6.5 Torque Converter lock up switch
Old Dec 16, 2009 | 06:20 PM
12valvecory's Avatar
Default 6.5 Torque Converter lock up switch
my friend has a 1992 gmc diesel 6.5 turbo with a automatic. We want to put a lock up swith so we conceted a wire to the brown wire coming from the trans and ran it to a switch ran to a ground and it did nothing, i did it to my dodge and noticeds a huge difference. could some body tell me wat we did wrong or put up pics of the right thing we checked everything and every thing was right so we could us your help. thanks.
Old Dec 17, 2009 | 09:02 PM
dealwithit's Avatar
hmmmm, why would you need a switch for the lockup??? just hooking up a switch to a wire from the trans is no really the best thing to do, the wrong wire and you could blow something up pretty quick.
Old Dec 17, 2009 | 10:59 PM
Woody35's Avatar
there is a diagram somehwere but i cant find it. i do agree its dangerous and you can blow your torque converter up pretty quick but if you use degression and use it at the right time you should be fine
Old Dec 18, 2009 | 09:48 AM
i know its the brown wire from the transmission and this is the brown wire from the tranny but it does not seem to lock up the tranny like it does in my dodge it just seems to make it shift faster.
Old Dec 24, 2009 | 08:36 PM
well i found this dill that said how to do it but we still are not sure but we sure could use the help thanks
Old Dec 30, 2009 | 05:18 PM
Larry6.5's Avatar
Default Manual lock up
you need a 3 pole 2 posistion switch.The brown wire from the transmission goes to the ECM,it controls torque converter lock up,cut the brown wire in 2 connect a wire to both ends,run the wires to the switch,connect the wire from the ECM to the bottom terminal of the switch,connect the other wire from the transmission to the center terminal,connect top terminal to a good ground.You are done.In one posistion you will have factor settings,in the other posistion you are making the torque converter to lock up,this set up is only good for slowing you down when towing. This is for 4L80E Transmission.I hope this is helpful
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Cody Cain
Dec 22, 2014 01:27 PM
Cody Cain
Dec 21, 2014 06:50 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
