Just another Fummins with lots of pics!
Old Nov 17, 2009 | 12:22 AM
bajabomber87's Avatar
Default Just another Fummins with lots of pics!
Ok so I started out with a 1991 F 350 7.3L zf-5 truck.
Pulled the front clip
Pulling the piece of crap idi
Yay new powerplant
I scored like no other with this non 53 block 01 24v. 100k miles, turbo, radiator, intercooler, boost tubes, wiring, computer, and hydroboost for $1650!
Stripped of wiring and cleaned up somewhat
Getting ready to start the fabwork
All cut out
Old Nov 17, 2009 | 12:24 AM
Setting it in for mock up and days of staring
Firewall clearance
All tacked in
Made the mounts out of 1/4'' plate, and the crossmember tubing is 1 3/4" DOM tubing, but what ever it was, had a higher rating than normal because it was tough on my bender.
All welded up and re-plated the passenger side inner frame rail
Driverside all welded up
Driverside top of framerail
Old Nov 17, 2009 | 12:25 AM
Primered shows up a little better
After an hour of wrestling it in by myself
Need to tack a piece of scrap to hold the front of the engine up so I can roll the truck around.
Crossmember to oil pan clearance
Old Nov 17, 2009 | 12:26 AM
Sits pretty low
Tomorrow I'm planning to start mounting the Dodge radiator and intercooler and adapt the front of the frame to hold it. By having the engine a few inches forward than normal, I'll have to do some trimming on the Ford core support and grill.
Or I'll just build a tube core support and make it work
Plans for the rest of the build is an NV5600, south bend con ofe clutch and flywheel, BW 13-56 t-case, FASS 95gph, 100-150hp injectors, Adrenaline w/pulse control which will save me on having a bunch of gauges, putting brand new Dodge hydraulics in for the slave, eventually putting twins in whether it be on my own or in a kit, o-ringing the head, head studs, blending the dodge gauge cluster into my Fords dash, reusing my 4'' exhaust, new white paint with pearl, new glass all around, and installing my 2nd gen Dodge seats too.
Any comments, advice, feedback is gladly WANTED/needed.
Tyler
Old Nov 17, 2009 | 02:16 AM
coyropin's Avatar
looking good nice fab work
Old Nov 17, 2009 | 08:06 AM
12vcummins96's Avatar
nice
Old Nov 17, 2009 | 08:21 AM
94Matt's Avatar
Nice job
Old Nov 17, 2009 | 09:00 AM
2500HeavyDuty's Avatar
damn thats clean. what made you do with a 24v
Old Nov 17, 2009 | 09:41 AM
K50's Avatar
K50
Man that looks awesome!! Nice work
Old Nov 17, 2009 | 09:48 AM
Wyatt Earp's Avatar
Nice...
