timing question.
Old Oct 29, 2009 | 05:31 PM
monster12valve's Avatar
Default timing question.
191 dv's, 370 non marine spray injectors, 100 plate.... will it hurt if i dont advance timing for a month or so?
Old Oct 29, 2009 | 06:33 PM
12vcummins96's Avatar
u should be fine but when u do the timing i would bump it up to about 16.5
Old Oct 29, 2009 | 08:33 PM
Shea@L&N Performance's Avatar
FormerVendor
Ditto, dont go much or any higher than that or it will be spraying out of the bowl
Old Oct 29, 2009 | 09:50 PM
12valvetater's Avatar
not only that but more timing means higher cylinder pressures 16.5 is max for stock head bolts and no orings
Old Oct 30, 2009 | 05:40 AM
cool. 16.5 it is. thanks guys!
Old Oct 31, 2009 | 02:30 PM
shortbusdriver's Avatar
he said non marine spray pattern, that would make them 145*. You will be fine advancing your timing well past 20* and still be in the bowl.
marine injectors start spraying out of the bowl around 19* depending on what other upgrades you have
quiksilver1j
Jul 30, 2015 12:41 PM
cummins Pride
Dec 31, 2014 12:58 PM
12vdriver21
Dec 29, 2014 07:46 AM
SMatyac
Nov 15, 2014 07:35 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
