6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Intake Manifold
Old Oct 22, 2009 | 01:24 PM
antibullock's Avatar
Default Intake Manifold
what intake manifold are you guys running?
Old Oct 22, 2009 | 07:32 PM
tdiezel's Avatar
AFE Bladerunners and ATS Arc-Flow are the most common intake manifolds I see. Of course there are a lot of people fabricating their own.
Old Oct 22, 2009 | 08:30 PM
HeavyAssault's Avatar
There's two parts to the intake (post IC). One is the intake elbow that takes the cold IC side air flow and directs in into the intake manifold. The 6.0 intake manifold houses the EGR valve, and runs in a "U" shape over the heads.
I run the Accufab Power elbow and have been very happy with the results. I have one port that I use to monitor the boost PSI. For the cost it's worth it to me.
There's only one person I know of that is selling a modified intake manifold for the 6.0s.
Old Oct 23, 2009 | 07:48 AM
I ment the elbow. Sorry. If the elbows taped can you monitor boost with that?
Old Oct 25, 2009 | 04:34 PM
Yes...you could tap the OEM or get one aftermarket with a single tap or multiple taps.
Old Oct 27, 2009 | 07:43 AM
thanks
Old Nov 12, 2009 | 06:01 PM
bobfbigman's Avatar
I use the large mouth CFM elbow, matches up to the 31/2 cooler tube for the banks cooler, they have the stock size also, these are composite so they don't transfer heat into the intake..
caissiel
Sep 24, 2015 05:37 PM
Old12er
Feb 20, 2015 10:35 PM
jrsavoie
Feb 6, 2015 09:44 PM
Finn92
Jan 6, 2015 05:54 AM
12vbomber
Nov 4, 2014 10:04 PM
