05 Cummins turbo noise
Old Oct 17, 2009 | 11:00 AM
gregg479's Avatar
Default 05 Cummins turbo noise
I just bought a 05 cummins 4x4. I didn't notice a squealing when I bought it. But now when I excelling the turbo changes tunes like squalling. How can i check the turbo out. BTW I have a afe intake and cat delete. Thanks for the info. LOVE the site.
Old Oct 17, 2009 | 11:34 AM
wildbill's Avatar
Remove the intake and check for play by grabbing the shaft and see if you can pull it back and forth or side to side movement.
Old Oct 17, 2009 | 03:57 PM
AHolt's Avatar
I had a squealing noise in mine also. Turned out to be bad oil pump.
Dealer said bad sending unit,drive it until we get another. They
ended up replacing my motor from bad oil pump which caused
turbo bearings to go out and ruined motor.
Old Oct 17, 2009 | 10:07 PM
gregg479's Avatar
Thanks I will check the turbo...(hope its not the oil pump...)
Old Oct 19, 2009 | 09:25 PM
wildbill's Avatar
Updates??
Old Oct 23, 2009 | 10:48 PM
wildbill's Avatar
Closing thread due to inactivity. Thread starter can reopen.
huntman7
Sep 27, 2015 10:41 AM
huntman7
8
Aug 28, 2015 05:42 PM
mr. dune-a-holic
May 4, 2015 01:39 PM
Jan 28, 2015 03:30 AM
Oct 24, 2014 04:40 AM
