psd power steering weak at low speed
Old Oct 7, 2009 | 10:30 PM
tigbench's Avatar
Default psd power steering weak at low speed
2001 superduty power steering at times has very little assist at low speed like when turning into a parking spot etc.fluid level is up, pump seems to have enough assist when at speed and no excessive noise coming from the pump.but when turning at just off idle its like manual steering.tires are 305s not too much larger than stock.anyone else experience this, any fixes ?
Old Oct 7, 2009 | 10:38 PM
blk99's Avatar
mine does it... havent gotten around to fixing it...
but i plan to flush the whole system with synthetic ATF to see if it stops the noise and lack of low speed steering....
the brakes are run off the PS system too so parking lots are no fun (low speed and using both brakes, steering)....
Old Oct 8, 2009 | 01:25 PM
Superstroker10's Avatar
try a flush
Old Oct 8, 2009 | 09:20 PM
Ibleedblue's Avatar
I have this problem too. I also have the brake pedal get soft when getting off the highway if put it in neutral and instead of down shifting.
Old Oct 9, 2009 | 01:43 AM
tigbench's Avatar
Default power steering
have tried flushing system /synthetic fluid ..lucas oil etc.anyone one know of a aftermarket pump with more flow/pressure that might work to improve this issue .seems that more than a few of these trucks have a similiar problem.thanks
Old Oct 10, 2009 | 04:22 PM
Derek0525's Avatar
I have an upgraded one from Nolimit4x4 it can be used with or without ram assist supposed to have more flow never got around to installing it plus I lost the instructions somewhere might get rid of it if you want it.
Old Nov 1, 2009 | 02:45 PM
crazyjayz's Avatar
hey yea my 01 is doing it too if you are still getting rid of that up grade i am interested
Old Nov 3, 2009 | 11:58 AM
Derek0525's Avatar
yup im still getting rid of it but like I said I don't have the instructions for it anymore
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
robbyS
Apr 16, 2015 02:22 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
