CUMMINS TROUBLE!
Old Oct 4, 2009 | 06:33 PM
simonswrecking's Avatar
Default CUMMINS TROUBLE!
94 CUMMINS 119,000 MILES RUNS BUT HAS NO POWER HAS SEVERAL FUEL LEAKS (ONE ON TOP OF PUMP ON INJECTOR LINES) MAKIN SURE I SHOULD START HERE OR IF ITS SOMETHING MORE SERIOUS? SMOKES WHITE WHEN IDLING, BLUE WHEN REVVED UP. JUST DOESNT SOUND RIGHT WHEN YOU REV IT UP. ANY HELP?
Old Oct 4, 2009 | 07:57 PM
j_hlad's Avatar
white smoke=moister
blue smoke= oil
could be missing when reved up due to lack of fuel no getting to pump
Old Oct 9, 2009 | 07:58 AM
SPLnut's Avatar
I'd start by fixing the leaks and then check the timing...Also check the turbo for oil leakage on the compressor side...
Old Oct 10, 2009 | 12:01 AM
What he said ^^^^
Old Oct 10, 2009 | 07:38 PM
Pyro690's Avatar
Where exactly would oil leak on the turbo? I'm kinda diesel dumb, but I'm trying.
Old Oct 10, 2009 | 08:20 PM
gradyc's Avatar
The engine oil pressure is fed to the turbo to cool and lubricate the shaft bearings. The shaft seals behind the turbine blades can leak and put oil in the air stream. If the drainback line is restricted and the oil can't get back into the crankcase quickly excess pressure can build on the seals and make the problem worse. If it is the intake side seal that is leaking the oil will go through the engine and burn as fuel and if the exhaust side seal is leaking the oil just goes out with the exhaust.
Old Oct 10, 2009 | 08:42 PM
wildbill's Avatar
Updates??
Old Oct 15, 2009 | 11:37 PM
wildbill's Avatar
Closing down for now. Thread starter can reopen and update.
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
hurriedcoyte
Jun 19, 2015 06:26 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
