Dodge Diesel Tech Articles All Years of Cummins Tech Talk
1st Gen ABS Operation And Diagnostic
Old Sep 25, 2009 | 08:03 PM
RSWORDS's Avatar
Default 1st Gen ABS Operation And Diagnostic
Here You Go Guys
http://issuu.com/rswords/docs/1st_ge...i-lock_brakes#
Old Oct 4, 2009 | 09:29 AM
RSWORDS's Avatar
Does this work for you guys? Can you see/read the PDF? Does the link work?
Old Oct 4, 2009 | 10:26 AM
muskrat's Avatar
Very nice, Bobby.
Old Oct 4, 2009 | 12:24 PM
tower_ofpower's Avatar
indeed thanks; only prob is they dont specify where the diagnostic ground is located at. i'm sure if i look behind the glove box it wont be hard to find... but this helps alot i choose to ignore the lights; but i'd rather not have to... got anything for the grid heater? they cycle while engine is running but dont pre-heat when the key is turned on. i assume the IAT sensor is ok since if you leave ti unplugged the wait to start light has a tendancy to flash
Old Oct 4, 2009 | 01:10 PM
RSWORDS's Avatar
Old Oct 5, 2009 | 08:26 AM
well i guess is throwin a DTC 4... i'm getting the impression a new hydraulic valve is in order... i know the speed sensor isnt any good (i've ohm'd it and got a nice little "O.L") so thats... half of the problem i suppose... i know my rear brakes work as i've had the rear end start to come loose wile braking in a corner
Old Oct 5, 2009 | 04:04 PM
RSWORDS's Avatar
For what its worth i disconected my ABS...
Old Oct 5, 2009 | 04:09 PM
12vcummins96's Avatar
great info bobby
Old Oct 5, 2009 | 04:18 PM
RSWORDS's Avatar
All I did was scan it in!
Old Oct 5, 2009 | 10:09 PM
well that's what i opted for today... maybe some day i'll just scrap the chunk of metal in the frame rail and run a straight line to the axle hose
