truck wont start
Old Sep 24, 2009 | 12:09 PM
stroker3507.3's Avatar
Default truck wont start
i have a late 99 f250 i orderd a dp tuner i went ot put i tin turn key no wait to start light unplugedd dp tuner wait to start light came on now i have no wait to start light motor cranks over wont start service egine light on i hooked ob2 up and i cant get in any help please
Old Sep 24, 2009 | 12:47 PM
CoalTrain99's Avatar
You didnt clean the ports on the ECU with a scuff pad. It cleans all the silicon off where you plug the tuner in. Your truck wont start unless they are clean. Go take it apart and clean the ports where you plug the tuner in. It will solve the problem guranteed.
Old Sep 24, 2009 | 01:59 PM
CSIPSD's Avatar
When you removed the chip did you have the keys in your hand and or the battery unhooked? If not you may have fried the PCM.
So you installed the chip, and it would not start. No WTS light nothing. Then you removed the chip and you get a WTS light but it will not start? Just trying to understand what your saying.
As was said above, try cleaning the PCM contacts better. But if it will not start now with the chip removed I would bet money you have cooked the pcm.
Old Sep 24, 2009 | 06:43 PM
i think i left the keys in the iqnition maybe so i prob did fry it can i take a pcm out of a auto and put it in my truck or no cause mine is stick
Old Sep 24, 2009 | 07:11 PM
CSIPSD's Avatar
Auto might work, but it may not start due to some inputs not being there. I would bet you will need a new PCM.
Old Sep 24, 2009 | 09:13 PM
yea i orderd a new pcm itll be here next week
doublehbar
13
Aug 9, 2015 12:35 AM
doublehbar
33
Jun 5, 2015 11:38 AM
dfish001
Mar 30, 2015 03:07 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
ronstop
Feb 26, 2015 09:48 AM
