no OD or lockup cummins
Old Sep 6, 2009 | 05:57 PM
coalroller05's Avatar
Default no OD or lockup cummins
so my 94 cummins lost od and lockup, it was searching back and forth from 3rd to OD then lost it. going through town it will get lockup at slower speeds but will never get OD. i took it to a trans shop and they said it needs a throttle position sensor... anyone ever run into this? they said its a common problem.
Old Sep 7, 2009 | 09:18 PM
cummin_un_glued's Avatar
FormerVendor
check the trans fuild sensor that is plugged into one of the tranny lines.....if it is unplugged for some reason that will happen
Old Sep 10, 2009 | 10:41 AM
stkdram55's Avatar
updates??
Old Sep 10, 2009 | 07:57 PM
well i tested my throttle position sensor and that tested out ok. i said screw it and threw a trans temp sensor in it and it fixed it. so were back on the road again foggin out hybrids
Old Sep 10, 2009 | 08:11 PM
wildbill's Avatar
Good deal. Going to close down the thread.
Shun70
Diesel Engine Conversions
Sep 21, 2015 01:39 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
Oct 20, 2014 08:10 AM
