still no go
Old Aug 25, 2009 | 12:46 PM
snowlvr's Avatar
Default snowlvr 6.4L wont go
was looking for an answer on my 6.4L ford....it acts as though the dpf or doc is clogged.... runs decent however restricted when first started warm or cold, then a few minutes of normal driving brings on a surious amount of mhat seems to be lag....and will only produce about 70% of hp.....if i ignore the problem and keep driving it seems to go into a backdown mode or something and wont accellerate at all, if i lay on the go pedal it will slowly build enough boost to take off...and i mean slowly. if it sounds like the dpf like i thought, i will delete it....any suggestions???
Old Aug 25, 2009 | 12:51 PM
wildbill's Avatar
Is it fully stock or does it have any mods??
Old Aug 25, 2009 | 12:53 PM
snowlvr's Avatar
the truck has afe stage 2, mbrp exhaust, and edge juice w/attitude stacked w/a superchips cortex......6in lift on 37s
Old Aug 25, 2009 | 12:58 PM
wildbill's Avatar
Remove the boxes and see if it helps. Chances are you lost an injector and it melted the DPF.
Old Aug 25, 2009 | 01:05 PM
snowlvr's Avatar
it has thrown several codes, one is a turbo performance code , the others are dpf and egr codes which lead me to believe that it is the dpf or doc causing the problems....computer reading to much backpressure and shutting it all down.....also will throw MAP/EBP corelation code from time to time
i have had the boxes off with no change in performance...
has also had out of ordinary EGTs....does that help??
once had an injector curcuit code and took it to ford..... they siad it was the juice that caused it...i sent it back to EGDE and they sent me a new unit.....havent had any problems w anything for a while outside of ford replacing the radiator and normal recall B>S>
Old Aug 25, 2009 | 01:06 PM
wildbill's Avatar
How does the engine run?? I mean any excessive amounts of white smoke, rough idle, lot of ticking??
Old Aug 25, 2009 | 01:10 PM
snowlvr's Avatar
if it lost and injector would it throw a code for that?? the dpf is an easy fix, the injector idea however is not........
no....the thing semms to run fine till you step on the go pedal
no funny noises at all and runs smooth, just seems to not want to go...like it has a Fing apple in the tailpipe
Old Aug 25, 2009 | 01:12 PM
wildbill's Avatar
As far as I know, it won't throw a code if an injector went out.
snowlvr's Avatar
no smoke at all
Old Aug 25, 2009 | 01:14 PM
wildbill's Avatar
I suppose you tried driving down the road to try and unclog the DPF.
