Perfromance trans won't shift at WOT
Old Aug 26, 2009 | 04:10 PM
brockdieseldude's Avatar
Default Perfromance trans won't shift at WOT
So here's the deal, I had a transgo shift kit SKFTOD installed with a new rebuild on the trans, now it won't shift out of 2nd gear unless you let out of it, but if you stand back in it, it will just shift back to 2nd and stay there. I then installed a new Dodge "RE" Governor Solenoid to GM Pressure Control Solenoid Conversion Kit and a Sonnex Throttle Valve Kit, didn't change a thing. I have adjusted the T.V. cable loose and back tight, checked all my pressure's everything is checking out. I have also change the T.V. spring from a very stiff green one to the softer orange one, I have called Transgo, and a few others but know one will give me any help on how to solve this, all they want to do is sell me another valvebody. The guy who built the trans did a very good job but he is also stumped on why this thing will not shift at W.O.T. Any help would be great guy's, thanks for reading
Old Aug 26, 2009 | 05:42 PM
mysterync's Avatar
I think Dave that works with Vulcan builds some trannys, I'll drop him a PM telling him to drop in and help you out!
Old Aug 27, 2009 | 08:01 AM
Budgreen's Avatar
Sounds like a valve body issue.
I would pull it and check all the holes are opened right and all the check ***** are in place.
Old Aug 27, 2009 | 10:59 AM
That would be great man thank you!!
Old Sep 10, 2009 | 10:48 AM
stkdram55's Avatar
updates??
Jake9473
Jul 22, 2018 08:19 AM
Rabbitjbu
Jul 28, 2015 06:03 PM
jrock0805
Jul 28, 2015 02:03 PM
yfzrunner
Feb 7, 2015 10:52 PM
99stackedpowerstroke
Jan 28, 2015 08:26 PM
