Truck won't start?
Old Aug 15, 2009 | 07:32 PM
Cummins Powered's Avatar
Default Truck won't start?
I own a 99 Dodge cummins. Recently it has been parked becuase i need new tires. I start it up every once in a while so that she knows she's gonna be driven again one day ha. But anyway. I started it up, revved her a bit, got her warm. Then shut her off and tried to start it again. It cranked and cranked but didn't start. I noticed that the "wait to start" light doesn't go on either, I asked someone about it and said it was my lift pump, could it be anything else as well?
Old Aug 15, 2009 | 07:46 PM
wildbill's Avatar
It's funny how the lift pump went just like that. See if you get fuel to the injectors. Simply crack a line and turn the engine over.
Old Aug 15, 2009 | 09:11 PM
I have cracked it open, and there was fuel on the fourth through sixth cylanders, but not the first or third, can't get the air horn off to see the second. I sprayed some starter fluid for diesels in and it still didn't start...
Old Aug 15, 2009 | 09:34 PM
Sounds like your IP.
Old Aug 15, 2009 | 11:01 PM
ha you'll call me stupid for this... but whats the IP?
Old Aug 16, 2009 | 12:27 AM
gradyc's Avatar
The IP is the injection pump. The only stupid question is the one you are afraid to ask. If you don't ask you won't learn.
Old Aug 16, 2009 | 12:42 AM
Mr. Miyagi's Avatar
Hook a jump charger up to it and try.
The pump is electronic...if you've been sitting for a while, starting, stopping, etc...you may have reached a point where the battery capacity is being used up by the starter with little to nothing remaining to power the electronic engine control system.
It is actually quite common....cranks fine, no start. Tell someone they need batteries and they look at you like you have a ***** growing out of your forehead.
Worth a shot...just to see...
Old Aug 16, 2009 | 01:01 AM
would the fact that the wait to start light doesn't go on have anything to do with it? I tried jumping it as well, didn't work
Old Aug 16, 2009 | 01:15 AM
Mr. Miyagi's Avatar
How about the Check Engine light..does it come on when you turn the key on?
With key on, engine off...the check engine light should stay on.
If not...along with the no wait to start light issue...the computer may not be communicating or getting power.
Check your fuses.
Old Aug 16, 2009 | 01:31 AM
The check engine light will come on, but it doesn't stay on. I've checked fuses, none blown except one, and i accidently blew that one myself it was the engine control fuse, but it wasn't blown before i don't think.
