How do i tune the afc?
Old Aug 9, 2009 | 06:12 PM
bowtech's Avatar
Default How do i tune the afc?
i hear about it all the time how i do it? like the star wheel and plunger? i would love some pics bc people like me with three number 21 chromosomes (down syndrome) like picture books jk
Old Aug 9, 2009 | 09:24 PM
relay93's Avatar
The way I see it, and it doesn't mean that I am correct, there are three things. 1st is the placement of the AFC housing on the pump the 2nd is star wheel which determines the amount of boost it will take to start moving the arm via the diaghram (sp?) and the 3rd is the smoke screw located on the back of the AFC housing which determines how much fuel from off idle with no boost. The 3rd pre-loads the AFC spring which moves the arm forward for no boost fuel from idle.
Old Aug 9, 2009 | 10:06 PM
bowtech's Avatar
where is the 3rd one? how you know if its good or what to mess with?
Old Aug 9, 2009 | 11:22 PM
tower_ofpower's Avatar
you should get a pretty good puff when you mash it on a dead stand still (no boost) 2 1/2-3 turns should get ya plenty of smoke and power w/o being excessive, reduce the spring tension on the afc and it'll bring your torque curve up abit being that it hits fuel quicker and not waiting until it has more air than it needs for the ammount of fuel actually being delivered
Old Aug 9, 2009 | 11:36 PM
bowtech's Avatar
2 3 turns on witch one? the smoke screw? where that on the back? where you have your star wheel?
Old Aug 10, 2009 | 06:19 AM
relay93's Avatar
Look at figure 4 of this link. http://www.tstproducts.com/pdffiles/INSRUCT98.pdf
The right hand side of the picture you will see a screw then below it a piece that sticks out it is a cover. You will need to remove this cover to adjust the smoke screw. When I installed the TST AFC spring the instructions said to back the screw off then turn the screw back in until it was making contact. This was to help control the off idle fuel from running rich which it controls the black smoke. When I installed the Gov springs I turned the screw in 2.5 turns whiched helped with starting.[URL="http://www.tstproducts.com/pdffiles/INSRUCT98.pdf"]
crpmap
Ford Powerstroke 08-10 6.4L
Aug 16, 2015 07:38 AM
crpmap
Jul 29, 2015 11:01 PM
NiNjAassasin545
Dec 2, 2014 11:40 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
